Home Forums Product Discussion & Questions BeoPlay Beoplay M3 line in sound skipping
  • #72496
    Peter8300
    I’m trying to create a setup where I connect a Beogram to a Beoplay M3 via line in and then do multi room to a Balance. The M3 is only supposed to be the gateway to the balance.
    However the sound is skipping all the time, so the setup is basically useless.
    If I disable delay in the B&O app the M3 plays just fine, but then I cant do multi room…
    Any ideas?
    #72505
    Guy
    Hi Peter and welcome to Beoworld!
    Have you tried changing the Line In detection level to ‘disabled’?  It’s the setting above the delay setting.
    Peter8300
    Hi Guy,
    Thank you.
    No haven’t tried that, will do so when I’m back home tomorrow and report back.
    I spoke with B&O support today and they suggested that it could be due to my mesh network..
    Peter
