Home › Forums › Product Discussion & Questions › BeoPlay › Beoplay M3 line in sound skipping
- This topic has 5 replies, 2 voices, and was last updated 2 months, 2 weeks ago by
Peter8300.
11 January 2026 at 19:20 #72496
Peter8300
BRONZE MemberI’m trying to create a setup where I connect a Beogram to a Beoplay M3 via line in and then do multi room to a Balance. The M3 is only supposed to be the gateway to the balance.
However the sound is skipping all the time, so the setup is basically useless.
If I disable delay in the B&O app the M3 plays just fine, but then I cant do multi room…Any ideas?
12 January 2026 at 12:01 #72505 GuyModeratorHi Peter and welcome to Beoworld!
Have you tried changing the Line In detection level to ‘disabled’? It’s the setting above the delay setting.
12 January 2026 at 13:05 #72507Peter8300
BRONZE MemberHi Guy,
Thank you.
No haven’t tried that, will do so when I’m back home tomorrow and report back.
I spoke with B&O support today and they suggested that it could be due to my mesh network..
Peter13 January 2026 at 21:08 #72529Peter8300
BRONZE MemberAfter disabling my mesh network and just going with one router everything now works fine.
13 January 2026 at 21:36 #72530 GuyModeratorAfter disabling my mesh network and just going with one router everything now works fine.
Good to hear – I hope it keeps working!
I meant to say, it could also be worth checking that your M3 is at the latest SW level – it should be at 6.5.57689.212515568 which was released on 22 October 2025. Full details of this and earlier versions are listed in the release notes here: https://update.bang-olufsen.com/products/b4ebddbebc6542ad87534e36f49d6a9a
14 January 2026 at 09:08 #72541Peter8300
Good to hear – I hope it keeps working!I meant to say, it could also be worth checking that your M3 is at the latest SW level – it should be at 6.5.57689.212515568 which was released on 22 October 2025. Full details of this and earlier versions are listed in the release notes here: https://update.bang-olufsen.com/products/b4ebddbebc6542ad87534e36f49d6a9a
Thanks.
Yes the software is fully updated.
