Home Forums General Discussion & Questions Home Automation Beoplay integration questions
  • #65028
    Frog
    GOLD Member
    The issue is that the integration isn’t fully formed (not a criticism btw) – what you need is a Chromecast Audio – the round puck which you can use as a media player – you connect it to the Line IN on the NL/ML Converter (you’ll need a 3.5mm to phono cable) and then you can play the media in two steps in the automation.
    Firstly in the automation get the chrome cast to Play Media (there you can select the source) – this will then start streaming to the NL/ML Converter. Then as a second step in the automation, get the Beosound 1 to play the Line IN
    I’m assuming you have a ML Gateway…
    #65032
    YannChris
    FOUNDER Member
    Thanks, Frog.
    I have no ML Gateway.
    Regards,
    Yann.
    My B&O Icons: No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available No description available No description availableNo description available No description available
