Home › Forums › Product Discussion & Questions › BeoPlay › Beoplay A9 keeps diconnecting
- This topic has 2 replies, 2 voices, and was last updated 2 years, 5 months ago by
hadraktas.
17 January 2023 at 10:17 #42941
hadraktas
BRONZE MemberHey everyone!
Happy New Year!
For a few weeks now, my Beoplay A9 (MkII) keeps disconnecting daily. The A9 appears as unreachable in the B&O app, and I have to take the plug out and force a restart in order for it to show up again. Sometmes this even happens while playing music, in which case the speaker is again unresponsive and I cannot turn it off even from the touch controls (I still have to plug it out). I tried Googling about this issue and searching the forums but nothing came up.
I believe that a new firmware was released recently and I thought that perhpas this might be causing the issue? Has anyone experienced something similar?
It is definitely not a WiFi issue, as the reception is quite good and stable (I have a 200Mbps FTTH connection, and everthing else works fine) and I don’t experience the same issue with a BS Stage nor a BeoSound 2 that are located further away from the router. I have also tried both the 5Ghz connection (which I normally use) and the 2.4Ghz, but the issue persisted regardless…
Any ideas on what might be causing this and/or what I could try to fix this issue?
Many thanks in advance!
Harry
edit: just saw that the post count was reset in the new forum. I’m an old member so I hope it’s ok if I post a new topic…
2 September 2023 at 13:03 #42942Darlon
BRONZE MemberSame problem here.Anyone got any solution to this problem as this is very frustrating.
14 September 2023 at 14:41 #42943hadraktas
BRONZE MemberI ended up selling the speaker and getting a Mk5 a few months ago. It was just too much of an incovenience to keep having to hard reset the A9 almost daily.
