Home › Forums › General Discussion & Questions › General Discussion & Questions › BEOPLAY A8
- This topic has 2 replies, 3 voices, and was last updated 2 months, 3 weeks ago by
matador.
4 August 2026 at 10:17 #124835
shoutj74
BRONZE MemberI have an ultrashort show projector from Philips (U4) with AUX out available for audio in our bedroom. There are a few Beoplay A8 available and I was thinking of using one for a main speaker for the UST projector.
- Would this work on a Mk 1 system
- Would I need to ‘power up’ the A8 or would it just work when it received an AUX signal from the projector
- Would the volume via the projector output work or would I have to change the volume on the A8
Any other thoughts/ideas for this setup. I have an original I-Pod which I could sit in the cradle to finish the look. I would love a Beosound 35 for this setup, but they are so hard to find. Any other ideas from the second hand market which others have used for something like this.
Thanks team!
4 August 2026 at 12:18 #124838 Millemis
BRONZE MemberI use my old Beoplay A8 for different test setup’s from time to time.
Once I had an Essence MK2 connected – a nice little setup!
The line-in there has autosense….it turns the A8 on, when there is sound coming.
It works well – some times it is a bit tricky, though.
.Basically you have two volume controls (maybe even 3, if you also have a source connected to the projector).
Best thing to do is to set the volume of the projector to fixed output or to a high start up volume…if possible.
And then control the volume of the A8.
Maybe you are lucky to get the small remote for it as well – or you can use a Beo4.The A8 is a good sounding ‘speaker’.
P.S. The original Beosound 8 does the job as well.
7 August 2026 at 12:10 #124866 matador
ModeratorIf you like the Beosound 35 form factor, you can try a Beolab 3500 with 1611 converter.
You’ll loose auto sense but you’ll win a second input you can use with a playmaker or an Airplay box and maybe a better stereo image.
Steve once told BL3500 are not good for TV due to lack of center channel.
Maybe that will be less noticeable with A8 but I think A8 is cute on a table, less to the wall where BL3500 shines.Location: Paris France
