Home › Forums › Product Discussion & Questions › Other › Beomedia 1 (type 1750)
- This topic has 8 replies, 4 voices, and was last updated 3 years, 9 months ago by
asgaard.
9 May 2022 at 11:32 #34717
asgaard
BRONZE MemberHi all,
Got from friend of mine Beomedia 1 , but unfornatelly the hdd is clean, there is no software whatsoever. I was hoping to have it downloaded from sites, but no joy so far. Once it is turn on it display B&O logo and then hard drive error which asks to Insert system disk and press enter. Do you have by any chance firmware/software for that model, please.
25 May 2022 at 19:07 #34718 BeobuddyGOLD MemberHave you tried to enter the BIOS and look whether the harddrive is chosen as first bootable drive? It might be the CMOS backup battery which fails and therefore settings are lost.
25 May 2022 at 23:25 #34719asgaard
BRONZE MemberNo, I haven’t tried that, but thanks for a tip. Once I will try I will keep posted.
12 June 2022 at 10:10 #34721 MillemisBRONZE MemberMaybe this can help:
https://archivedforum2.beoworld.org/forums/p/22108/182861.aspx#182861
12 June 2022 at 21:12 #34720asgaard
BRONZE MemberShort update:
Once it’s turn on, you can heard that the hdd plates are started spinning with clicking (probably hdd faulty) and message came up on the screen as Disk Boot Failure, insert system disk and press Enter. I tried to go to the Bios, but not sure which key on the keyboard should I press, and I tried already F8, F12, F10 but none of them are giving me access to BIOS.
12 June 2022 at 22:27 #34722asgaard
BRONZE MemberThanks for that, will keep you posted once tested.
13 June 2022 at 18:58 #34723asgaard
BRONZE MemberI have tested it, looks like hdd is faulty. There is no problem to get a replacement hdd (as in previous link) using adapter to convert from ide to sata, but I have no way of getting software of the Beomedia. All I found online was BeoPlayer, but not sure if anyone of you has a recovery copy of the system.
14 June 2022 at 10:22 #34724 Keith SaundersBRONZE MemberYou will not find the software on-line because B&O just added it to the recovery partition. You then go into the recovery via the BIOS. However as your disk apparently has totally failed you will need to get an disk image from another Beomedia 1
14 June 2022 at 20:55 #34725asgaard
BRONZE MemberI’m hoping that someone has a disk image for spare from Beomedia 1.
