Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 8000: Would there be any advantage to screwing a heatsink to TR211/207
- This topic has 2 replies, 2 voices, and was last updated 3 years, 7 months ago by
quattttro.
31 August 2022 at 04:12 #38748
quattttro
BRONZE Memberon the amp boards, #5. These run extremely hot on my 8000 (around 80°C at idle), and temp seems to be directly related to the no-load current measurement. Cooling them down with some compressed air lowers the voltage dramatically. Is this by design?
31 August 2022 at 16:37 #38749Dillen
ModeratorNo! It’s made like this and it’ll work fine.
(Actually the best and most stabile operating temperature for many semiconductors of this sort is 60-70 degC).Set the idle current as adviced in the service manual.
Final adjustments are done with the Beomaster under normal working conditions (warm).If the idle runs astray (keeps increasing, also after a few minutes) there is a problem
somewhere, – most likely lack of thermal coupling from the output stage darlingtons – or from the temp. sensing transistor in the constant current generator – to the cooling fins.(Never run an amplifier like this without the cooling fins – it’ll do a thermal runaway).
31 August 2022 at 16:52 #38750quattttro
BRONZE MemberThat answers that. Thanks!
