Home › Forums › Product Discussion & Questions › BeoSystem › Beomaster 7000 not responding to Beo4 remote
- This topic has 16 replies, 2 voices, and was last updated 1 year, 2 months ago by
Guy.
3 February 2025 at 10:56 #63346
Rob In der Maur
MemberI do have a Beosystem 7000 (master, CD, tape and gram) and a Beo4 remote with navigation buttons. I used to have a setup that also included a Beovision 7-32 trough a Masterlink and all controller fine from the Beo4 remote. I remove the Beovision 7-32 and Masterlink out of the equation due to a malfunction of the TV and now have only the Beosystem 7000 setup. I try to control the Beosystem 7000 with the Beolink 4 but whatever I do, it just does not work. I’ve reset the Beo4 multiple times, after which I configured it in OPTION > A.OPT > 1 as everybody is recommending but to no avail.
Do I need to program / reconfigure the Beomaster 7000 in some way to enable to receive IR transmissions again? Any help appreciated/.
3 February 2025 at 11:04 #63347 GuyModeratorThe BM7000 should be in standby (off) when you carry out the A.OPT 1 procedure – and I think that it should acknowledge the instruction in some way – either a flash of the standby light or a number in the display.
The A.OPT 1 procedure does not change the output of the Beo4 – it re-programmes the Beomaster to accept IR commands.
3 February 2025 at 11:11 #63350Rob In der Maur
MemberI have it in standby, but I don’t see any acknowledgement from the Beomaster 7000. Could it be I need to point it to the IR receiver more closely, and if so, where is that positioned on the Beomaster 7000. Or could another device (like the Apple TV I do have) capture the IR signal before it reaches the Beomaster 7000?
3 February 2025 at 11:17 #63351 GuyModeratorCould it be I need to point it to the IR receiver more closely, and if so, where is that positioned on the Beomaster 7000.
That shouldn’t be necessary* – but have you checked that the Beo4 is actually working (transmitting IR) by observing the end with an iPhone selfie camera?
* There is a setting for turning down the IR output on the Beo4, but we’ll come back to that once you have checked the above.
No. There have been reports of plasma TVs affecting IR signals, but this is unlikely.
3 February 2025 at 11:20 #63352 GuyModeratorCan you also confirm that your Beo4 has the little navi button in the centre of the arrow keys? Is it the one on the far right in the picture below?
3 February 2025 at 11:20 #63353Rob In der Maur
MemberI would be very coincidental if the Beo4 just gave up emitting IR signals at the same time I removed the TV out of my installation. How do I exactly check Beo4 remote working with an iPhone selfie camera?
3 February 2025 at 11:21 #63354Rob In der Maur
MemberAnd yes, I do have the most right Beo4 remote with the little knob instead of the GO button.
3 February 2025 at 11:24 #63355 GuyModeratorI would be very coincidental if the Beo4 just gave up emitting IR signals at the same time I removed the TV out of my installation. How do I exactly check Beo4 remote working with an iPhone selfie camera?
I agree, but worth checking! Just view the end of the remote with the selfie camera and you should be able to see the IR transmitters glowing faintly when you press buttons on the remote.
3 February 2025 at 11:37 #63357Rob In der Maur
MemberI can’t see anything lighting up from the Beo4 with little navi button (maybe it’s to faint?).
I do have another Beo4 however, the middle one in your picture, where I see faint red light appear when pressing buttons. However, trying A.OPTION > 1 with that one on the Beomaster 7000 still doesn’t do anything.
3 February 2025 at 11:39 #63358 GuyModeratorI can’t see anything lighting up from the Beo4 with little navi button (maybe it’s to faint?).
Strange. In that case you could try adjusting the IR power setting on that navi remote to the maximum.
Access the service menu by pressing stby + LIST at the same time, and then MENU + (joystick) at the same time. Press ^ several times until the display reads IRPWR: X. 1 is the lowest and 7 is the max IR signal strength (default is 4). Give 7 a try to see if that gets through to the BM7000 – try the A.OPT 1 setting procedure again.
If that doesn’t work, and given that the other remote also won’t control it, perhaps your BM7000 is faulty like the one in this thread: https://forum.beoworld.org/forums/topic/beomaster-7000-not-responding/
3 February 2025 at 12:28 #63359Rob In der Maur
MemberThanks, reconfigured the Beo4 remote like you. instructed. But still doesn’t work. Just to confirm, the IR receiver in the BM7000 is internal? I don’t need an external IR receiver for it? I dismantled so many things yesterday when removing the Beovision 7-32 out of the equation that I want to be sure about this.
3 February 2025 at 12:33 #63360Rob In der Maur
MemberLooking at this thread https://archivedforum2.beoworld.org/forums/t/18489.aspx, might there also not be an option to turn off the IR receiver at the BM7000 and I might have accidentally done that when resetting the Beo4? Because, before that, the remote was sort of working. And if that is another solution, question remains how to turn on the IR receiver on the BM7000.
3 February 2025 at 13:34 #63364 GuyModeratorJust to confirm, the IR receiver in the BM7000 is internal?
Yes it is. There was an external sensor available in case you wanted to put the main unit in a cupboard, but even fitting this wouldn;t disable the internal sensor.
Using the Beo4 remote to set A.OPT 0 stops the BM7000 from responding to IR commands. (Pedantically, it doesn’t actually ‘turn off’ the IR receiver, because you can use the Beo4 to set A.OPT 1 to get it to start responding again).
When you say that the remote was ‘sort of working’ before, was that when it was connected to the TV? In your earlier setup (with the TV connected to the BM7000 and the speakers connected to the TV), the TV would have been set to V.OPT 2, in which setting it would respond to both video (TV, DTV etc) and audio (RADIO, CD etc) commands – relaying the latter to the BM7000 over Masterlink. The BM7000 would have been set to A.OPT 0 where it would not respond to direct IR commands because it is getting them via the TV/masterlink.
So the BM7000 is either stuck in A.OPT 0, or there is a fault that stops it receiving (responding to) IR commands.
I assume that you were using a BeoLink 1611 converter to connect masterlink to the BM7000 – have you removed that from the system? If not, try disconnecting it from the BM7000.
3 February 2025 at 14:09 #63365Rob In der Maur
MemberWith “It was sort of working before” I meant after removing Beovision 7-32 and Masterlink from the system. It did work yesterday briefly when the system was finally a pure audio setup: Beomaster with a connected Beo CD, Beo tape deck and Beo record player (the complete set) and two Beolab 4 speakers attached to it. All is working fine when using buttons on the devices. It might have stopped working because I did a RESET? on the Beo4 (I wanted to clear out all config for the now gone TV), or just by coincidence . I just want to rule out all options before I decide to bring in the Beomaster 7000 for repair of a faulty IR receiver.
3 February 2025 at 14:28 #63368 GuyModeratorIt might have stopped working because I did a RESET? on the Beo4
RESET on the navi Beo4 should not affect the BM7000 IR receiver.
However, let’s check again by using your older Beo4 remote – you know this is working because you could see the transmitters glowing with your phone.
Re-try the A.OPT 1 procedure with the older Beo4. Be sure to follow the instructions preceisely, ie:
- Turn the BS7000 to standby/off by using the power button on the front panel.
- On the Beo4, press the POWER button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show A.OPT. Then press 1. The power light on the BM7000 should blink to show that it has been accepted.
If that doesn’t work, then on the older Beo4, try this:
- Power+ List together
- Press List till CONFIG appears
- Enter 2 0 0 2, and the display will say either LINK ON, or LINK OFF.
- Press Exit
- You need the screen to say LINK OFF, so repeat the above procedure until it does so (it will toggle each time the procedure is followed)
Then try setting A.OPT 1 again.
3 February 2025 at 16:08 #63373Rob In der Maur
MemberThat did the trick! Could not type in 2002 on CONFIG? on the new Beo4 remote for whatever reason, but could with the old one. Then successfully could sent with that same old remote A.OPTION > 1 to Beomaster 7000 (saw it being received) and then everything worked again; also with the new Beo4 remote.
Thanks you so much!
3 February 2025 at 16:32 #63374 GuyModeratorThat did the trick! Could not type in 2002 on CONFIG? on the new Beo4 remote for whatever reason, but could with the old one. Then successfully could sent with that same old remote A.OPTION > 1 to Beomaster 7000 (saw it being received) and then everything worked again; also with the new Beo4 remote. Thanks you so much!
Great news – I was beginning to give up hope. To be honest I am not 100% sure what the problem was but am very glad that it is working now. Thanks for your patience in experimenting with my ideas! 😀
