Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 7000 not responding to Beo4
- This topic has 6 replies, 5 voices, and was last updated 2 years, 11 months ago by
chartz.
15 April 2023 at 12:24 #45769
Poodles
BRONZE MemberHi everyone, I’m new to the forum. I recently got a few B&O products, but I am not able to get it working.
I have a beomaster 7000 and beogram cd 7000 hooked up to 2 beolab Penta’s, and trying to control them with a Beo4. However, it doesn’t respond to the remote. Also, whei put in a CD it is extremely loud, I can’t adjust the volume, and only coming from one speaker. What should I do to get this working?
15 April 2023 at 15:19 #45770 filip_kbhBRONZE MemberSet the Beomaster to Option 1. On your Beo4, press Standby button (the red dot) and List at the same time. Your Beomaster will turn off, and the Beo4 will show Option. Press 1 and Store or Go (I don’t remember).
15 April 2023 at 15:46 #45771 GuyModeratorSlight correction to above: After Power/LIST together, the Beo4 screen shows ADD. Press LIST until OPTION shows, then press centre button (GO) whereupon screen shows V.OPT. Press LIST until A.OPT shows, then press 1.
15 April 2023 at 16:45 #45772 carolpaBRONZE Memberor the Beo4 is set to continuously control a device set in option 4.
then search for “config” in list of the Beo4 and type “2002” to reset the Beo4 to normal functionality.
17 April 2023 at 09:30 #45773Poodles
This did the trick! Thank you so very much. It sounds so awesome.
Just wondering, with the active speakers, how do they know which is the left or right speaker? I have the right one on power link 1, the left one of power link 2. It does seem like it’s separating right now, just wondering if it’s correct.
17 April 2023 at 09:41 #45774 GuyModeratorJust wondering, with the active speakers, how do they know which is the left or right speaker? I have the right one on power link 1, the left one of power link 2. It does seem like it’s separating right now, just wondering if it’s correct.
Powerlink cables carry both Left and Right channels, hence each speaker should have a Mode switch on which you select L or R.
Now that you can remote control, you can adjust the balance to check that they are correct, and also store the preset start up volume on the BM7000.
18 April 2023 at 18:01 #45775 chartzBRONZE MemberI have the same system (BM5500 / CD5500/BG5005) and my Beo4 worked with it straight away.
