Home › Forums › Product Discussion & Questions › BeoMaster › SOLVED !! Beomaster 6500/7000 main relay RL1 spec search
- This topic has 5 replies, 2 voices, and was last updated 6 months ago by
nitro2.
5 September 2025 at 21:19 #69395
nitro2
BRONZE MemberI am looking for the specs of the replacement relays you can put into this beomaster .
i know the original is a
pASi KS/r-1-c 6v but thats it .
Is there a direkt drop in ??
6 September 2025 at 17:28 #69428 Guy
ModeratorI would probably buy one from here: https://www.dksoundparts.com/product/relay-for-beomaster-5000-5500-6500-7000/
7 September 2025 at 19:07 #69462nitro2
BRONZE Memberdk is modify-ing the relay ( most likely cutting of 2 legs ) ,
i only need to know what type / brand of relay they are selling
8 September 2025 at 10:39 #69469 Guy
ModeratorIn that case I don’t have the answer. I suppose that research into the relay type is part of what you are paying for when buying parts from Danish Sound Parts – to my mind it is worth paying a little extra for the peace of mind of a known compatible part.
One of the older archived threads may have the answer, or perhaps remove the relay and take to an electronics store and ask for an equivalent.
9 September 2025 at 08:10 #69492nitro2
BRONZE MemberGuy ,
Thanks for your answers !!
as there is no info avalable on the pASi relays anymore and the website of the new owner has no technical data ,
I will need to do a reverse search.
11 September 2025 at 14:47 #69541 -
