Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5500 speaker socket bad contact : known issue ?
- This topic has 7 replies, 4 voices, and was last updated 1 year, 10 months ago by
Glitch.
24 May 2024 at 10:06 #55928
pilatomicSILVER MemberHello,
For some time now I’ve had an ongoing issue with my Beomaster 5500 : poor contact on the speaker connectors, meaning that I have to move around the speaker plug before it makes good contact.
I have mostly fixed it by using the second pair of speaker terminal, as the issue is much less pronounced on those, but in doing so I lose the MUTE function.
I already had the Beomaster appart a few times, and I don’t recall seeing any cold solder joint in that area.
I also replaced the plug on the speaker wire and it did not make much change, confirming the issue lies on the Beomaster side.Now before I deep dive into this issue, is it something common and already known, or is my Beomaster an outlier ?
Thanks !
24 May 2024 at 12:31 #55929Die_Bogener
BRONZE MemberVery common is a corroded Mute relais. Replace it or clean it.
24 May 2024 at 12:55 #55931 pilatomicSILVER MemberHi Die_Bogener,
Thank you for the tip !I forgot to mention that I already did a full restoration of that Beomaster a few years ago, which included replacing the relays, so I know the relay is good.
(btw if you do so, make sure you use Cadmium plated relays for the power supply relay, newer, Non-cadmium relays really don’t last long with the inrush current).Also just moving a bit the speaker plug in the connector is usually enough to get it working back, so it really behaves like a connector fault.
24 May 2024 at 14:29 #55936Glitch
BRONZE Memberpilotomic: I had a similar issue with a different model Beomaster. The pins in the speaker connectors were worn to the point that they didn’t make good contact. I was not able to find the same style connector as a new replacement. My solution was to buy a different style, board mounted, speaker connector and swap the pins from the new connector into the original connector.
Another possibility is to remove the pins from the old connector and squeeze the pin tips together. I would see this as more of a temporary solution.
I probably have some pictures that would make the above descriptions make more sense. Let me know if you need any additional clarification and I’ll try digging through my photo archive to find them.
As far as the mute relay goes… Do you have any idea why B&O would only mute Speaker1 and not Speaker2 in the BM5500?
Glitch
24 May 2024 at 15:02 #55937 GuyModeratorAs far as the mute relay goes… Do you have any idea why B&O would only mute Speaker1 and not Speaker2 in the BM5500?
Glitch
Because the Spkr 2 socket is designed to supply Link Rooms via the MCL2 system, hence when pressing Mute you only want to silence the main room.
24 May 2024 at 17:19 #55939Glitch
BRONZE MemberGuy: That explanation makes sense. Thanks!
pilatomic: I found a similar speaker connector on my bench. A picture of one of the pins is shown below. HTH.
Glitch
24 May 2024 at 21:36 #55940 pilatomicSILVER MemberGlitch : I already tried to squeeze the pins together without taking the connector appart (using small pliers), it seemed to help temporarily, but not for long.
Thank you for the picture of the pin. I’ll look for potential replacement connector, but this type of speaker socket has been out of style for quite some time now, not sure if some PCB-solderable parts remains.
24 May 2024 at 22:34 #55942Glitch
BRONZE MemberFYI, that particular pin came out of panel mount, 2 pin DIN, female connector. These still seem to be reasonably easy to buy, but are of questionable quality. I agree that finding a NOS solder-able part is a long-shot, but I’ve been surprised before by what I’ve found for sale. I think that any possible solution is going to involve creativity, ingenuity, and some quality time with jeweler’s files.
Trying to look at the bright side, the pins from the panel mount connectors have the right the “business end”. The material between the pin fork and what gets soldered to the board is less critical.
On a similar subject, I’ve been thinking about replacing the 3 and 4 pin DIN speaker connectors with “something else”. Considering that the male versions of these connectors are essentially unobtainable, there appears to be a need here for those that are trying to keep the old equipment going. I assume that I’m not the first to consider this. If a solution exists, it would also solve the worn-out 2 pin connector dilemma.
Glitch
