Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5500 Master Control – rotary control only works in one direction
- This topic has 1 reply, 2 voices, and was last updated 3 weeks, 2 days ago by
17 February 2025 at 23:36 #63855
After many years of faithful service, my master control panel only works in one direction (turning anti-clockwise).
I realise it’s optical, but that bit is clearly working, correct?
Any pointers on how to troubleshoot would be appreciated.
18 February 2025 at 11:14 #63864From memory there’s also a little microswitch* next to the optical sensor. This is mechanically operated by the wheel and basically tells the system which way the wheel is turning. I would look at that in the first instance.
(* as opposed to a ‘big’ microswitch 😀)
EDIT2: This thread discusses the problem and has a useful photo of the switch: https://archivedforum.beoworld.org/forums/t/35687.aspx
This reply was modified 3 weeks, 2 days ago by
