Home Forums Product Discussion & Questions BeoMaster Beomaster 5500 Master Control – rotary control only works in one direction
  • This topic has 1 reply, 2 voices, and was last updated 1 year ago by Guy.
  • #63855
    dave_n_s
    After many years of faithful service, my master control panel only works in one direction (turning anti-clockwise).
    I realise it’s optical, but that bit is clearly working, correct?
    Any pointers on how to troubleshoot would be appreciated.
    #63864
    Guy
    From memory there’s also a little microswitch* next to the optical sensor.  This is mechanically operated by the wheel and basically tells the system which way the wheel is turning.  I would look at that in the first instance.
    (* as opposed to a ‘big’ microswitch 😀)
    EDIT2:  This thread discusses the problem and has a useful photo of the switch:  https://archivedforum.beoworld.org/forums/t/35687.aspx
