Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5000 cuts out after 20seconds – what are the trimmers?
- This topic has 5 replies, 4 voices, and was last updated 2 years, 5 months ago by
matador.
2 November 2023 at 10:23 #50077
molivethorn
BRONZE MemberThanks for your time!
I have seen some other posts about this problem but i could not actually identify the parts that those solutions referenced… something about the idle current trimmers?
the issue is that the amp cuts out and goes back to idle every 20 seconds. (red dot on screen showing it has power) this is weather it is playing music or not, with everything plugged in or nothing plugged in, it doesn’t make a difference.
I have basic/no electronics knowledge, i can do basic soldering but not much more.
I have opened up the amp, dusted, used an airbrush to blow out all the dust. i cant see any obvious broken connections etc.
The only thing that is broken on it is the front panel does not actually shut properly, although i doubt that would link to this issue?
Thanks for any recommendations you have.
3 November 2023 at 00:23 #50078 Mark-sf
BRONZE MemberIf you don’t have any test equipment such as a multimeter and oscilloscope, you should have it looked at by a B&O service tech.
3 November 2023 at 08:34 #50079molivethorn
BRONZE MemberI thought that might be the case. Sadly my nearest B&O service place bumped me to here! They weren’t interested at all in fixing a vintage piece.
I’ll try some local hifi guys.
3 November 2023 at 09:45 #50080 GuyModeratorI’ll try some local hifi guys.
Roughly where do you live? – a forum member may be able to suggest a specialist.
3 November 2023 at 10:10 #50081molivethorn
BRONZE MemberI am just north of Bristol.
Any recommendations would be welcome. (I have found three places with a quick Google search)
3 November 2023 at 18:31 #50082 matador
ModeratorTo answer the basic question of the title of the topic, trimmers are the variable resistors used to, in that case, adjust the idle current.. Find the service manual, the process is detailed and almost possible to anybody with a multimeter.
The beomaster 5000 is a complicated piece but it really worth working on it.
Godspeed.
