Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 4500
- This topic has 4 replies, 2 voices, and was last updated 2 years, 3 months ago by
kronzilla.
13 December 2023 at 07:53 #51256
Dillen
ModeratorDid you try the method stated in the service manual?
13 December 2023 at 10:20 #51257kronzilla
BRONZE MemberHello Martin,
It seems that i did not find the method described, or i overlooked it. Would you be so kind to write it down here for me? ?
Thank you for the fast reply
David
13 December 2023 at 12:46 #51255kronzilla
BRONZE MemberHello, i serviced a bm4500, also replaced the battery in the processor box with a battery and a fresh battery. Everything works, exceptbthat it serms that you must re-program it ( little bit like BC9500) but the key combinations for bc9500 dont work. Inset it in mode 1 with a beolink 1000. I can not store volume treble and bass settings. (S/W is version 1.6)
I serviced a beomaster 3500, after i set it in mode 2 everything works perfect. I did test the bm with the beolink 7000 and no communication.
the volume changes and gi then with a letter from the alphabet but not to zero… Can somebody give me the key combination? Before i changed the battery, everything worked perfectly. I replaced the battery prevently against future leakage.thank you in advance
13 December 2023 at 13:08 #51258Dillen
ModeratorIn test-mode press 7 to delete RAM settings and revert to defaults.
Service manual page 7-2 and 7-3 describes it.Martin
13 December 2023 at 13:29 #51259kronzilla
Thank you ??
I did not read it in the manual. Feeling a little dumb now ??
David
