Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 4500
- This topic has 3 replies, 4 voices, and was last updated 3 years ago by
Dillen.
25 March 2023 at 06:48 #44966
loureed5
BRONZE MemberHoping for an easy fix to my Beomaster 4500.
Turns on but won’t play anything.
Comes on with a “code” message.
All functions are not able to play. I tried a re-boot to no avail.
Would be very grateful to find a solution that I could try ?
(Nearest service centre is 70 miles away, and charges a fortune just to look at it ).
25 March 2023 at 20:20 #44967 GuyModeratorIt sounds like the 3v lithium battery supplying the microprocessor needs replacing – quite a common fault. It is soldered in place hence requires some technical knowledge and soldering skill to replace. Have a search of this and the archived forums for advice and/or join as a silver or gold member to download the service manual.
26 March 2023 at 10:04 #44968Pindsen
BRONZE MemberHi,
Could you explain what this “Code” message tells.
I have had several BM3500/4500 with faulty backup battery but they still work they just don’t remember the settings after power has been off.
Some BM3500/4500 have trouble with the Mute relay on Speaker 1, do you have the same problem when you connect your speakers to Speaker output 2?
Can you operate the Beomaster via the front touch buttons?/Pindsen
26 March 2023 at 11:26 #44969Dillen
ModeratorA Beomaster with a bad backup battery can act up in different ways.
If nobody knows which settings and what content is being stored in memory, things really
get quite unpredictable.Martin
