Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 4000 tuning lights & meter
- This topic has 2 replies, 1 voice, and was last updated 5 months ago by
Paul Vernon.
6 May 2026 at 16:50 #123499
Paul Vernon
SILVER MemberI have just refurbished my BM4000 with the Danish sound parts kit, everything is working well apart from the tuning signal lights and meter. Both side of the lamps have 15 volts (hence no light) and from the diagram there should be 8.8v at TR11-15.
Are there any tips or common faults with this circuit ?
Paul
Favourite Product: Beogram 4000
7 May 2026 at 17:55 #123512Paul Vernon
SILVER MemberCan I also add that the collector of TR9 has zero volts, I can’t figure why.
Any ideas?
Cheers
Paul
You must be logged in to view attached files.Location: Brighton UK
20 May 2026 at 14:17 #123672Paul Vernon
SILVER MemberOK folks
I have fixed the problem, I just needed to increase the level in the front end by adjusting trim pot 74. All lights working now.
Paul
