Home › Forums › General Discussion & Questions › General Discussion & Questions › beomaster 3500 glass panel broken
- This topic has 3 replies, 3 voices, and was last updated 1 year ago by
Guy.
26 February 2025 at 12:05 #64081
mark. hinks.
SILVER MemberIve caught the B&O bug.
I bought a beomaster 3500 which I now have fully working.. apart from the bottom glass touch screen panel is broken .. due to my leaving it in a bad place and a nosey cat.
Does anyone have one or is there something from another machine that may fit?
Dream audio vision no longer makes them unfortunately.
I am also after a mmc4 or similar for the beogram 3500, that’s now working perfectly apart from the stylus that is worn out.
How long does this addiction last ?
28 February 2025 at 09:38 #64182 HiortGOLD MemberMaybe you could buy a non working BM3500 and use that as the donor for your Beomaster?
The addiction is lifelong 😀
28 February 2025 at 10:07 #64183mark. hinks.
SILVER MemberI feel you may be right about the addiction.
Yes keeping my eyes open for a bm3500.
28 February 2025 at 10:53 #64188 GuyModeratorMaybe you could buy a non working BM3500 and use that as the donor for your Beomaster?
The danger is that you then end up fixing the ‘donor’, still need a glass panel and the search goes on for a third … 😀
