Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 3500 and BeoLab 4000 / 6000
- This topic has 3 replies, 3 voices, and was last updated 6 months, 2 weeks ago by
Steen Blæsbjerg Nielsen.
9 September 2025 at 18:28 #69511
BRONZE MemberHi all,
I own a Beomaster 3500. Is it possible to connect BeoLab 4000 or 6000 active speakers to the system? If so, how to?
I realise i cannot use the speaker output, since it would ‘kill’ active speakers.
Thank you in advance!
9 September 2025 at 19:42 #69513Madskp
GOLD MemberYes it is. You will have to use the connectors marked Powerlink and connect to the speakers with Powerlink cables
9 September 2025 at 21:06 #69520 GuyModeratorFurther to madskp’s response, I think the Mk3 Powerlink cables will be fine in this situation – available from Sounds Heavenly here: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
11 September 2025 at 10:51 #69539Steen Blæsbjerg Nielsen
BRONZE MemberThanks for your replies! I will go ahead 🙂
