Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1400 buttons
- This topic has 5 replies, 4 voices, and was last updated 3 years, 5 months ago by
Pindsen.
17 October 2022 at 08:16 #39945
Pindsen
BRONZE MemberHi,
Working on a BM1400 Type 2659 I have that almost all buttons are stuck – they do not move. I am trying to push and pull while using contact cleaner but it do not make a change – what do I do?/Pindsen
17 October 2022 at 23:59 #39946 Mark-sfBRONZE MemberYou will need to open the top and remove the front panel as if I remember the switch assemblies are board mounted. Once you have access, you can see what is hanging up the interlock mechanism.
18 October 2022 at 15:28 #39947Dillen
ModeratorThe buttons are stuck in dry lubricants.
Pull the knobs off, clean both sides of the metal blade for each knob and the respective
mating slot in the knobs plastic backside.
Contact cleaner can often help dissolve and shift the dried stuff.
Sometimes IPA is better. Try and see.
Pipe cleaners are good for cleaning both parts as they can be shaped to suit and will fit nicely in the slot.
When clean add a little silicone grease (of the non-hardening type) to the slot in the
plastic backsides and push back the knobs.All this can be done from the front.
If a knob is really stubborn, you can lever it off careful using a flat-bladed screwdriver
from below into the knobs recess and against the front frame with pieces of thin cardboard between to avoid scratching.Martin
23 October 2022 at 10:20 #39948Pindsen
BRONZE MemberHi,
Thank you for the description, I had not noticed the ability to pull the knobs off like you mention. Then I might have another issue, and that is that the buttons do not thay IN when being pressed. There was a small blade spring that has become loose, it was attached to the P2 button on the side but despite trying mounting it differently I cannot make it work – I assume it have something to do with the plastic thing moving underneath the buttons?
Can you help with that also?/Pindsen
23 October 2022 at 10:30 #39949 chartzBRONZE MemberGood luck and remember, we love pictures here.
26 October 2022 at 19:27 #39950Pindsen
BRONZE MemberHi,
I can very well end this thread by saying that I figured out how it worked. So the spring-back effect was controlled by the bronze metal spring attached on the P2 button but due to metal fatigue it had no effect anymore so I had to create a new spring effect. It is impressive these small detailed engineering techniques B&O has created over years.Location: Denmark
