Home Forums Product Discussion & Questions BeoLink beolink passiv always on
Viewing 13 posts - 1 through 13 (of 13 total)
  • #65665
    ballingfisker
    SILVER Member
    my beolink passiv can not turne off. anyone have a tip.
    Favourite Product: beosystem 3500
    My B&O Icons: No description available No description availableNo description availableNo description available
    #65668
    Madskp
    GOLD Member
    Just to be sure what you mean by always on you might need to clarify in what context it is used as it can be used for the following usecases:
    – Link room
    – amplifier for passive speakers
    – converter for Masterlink (ML) to Master Control Link (MCL)
    Next,how you can tell it is allways on? Is the green LED on the box allways  on?
    #65673
    ballingfisker
    SILVER Member
    i want to use it as power amplifire , nothing connecet ,when i connect powercord it turns on
    and i cant turn it off ,and when masterlink cable is connecet it is the same.
    #65675
    Madskp
    GOLD Member
    Not sure what could trigger this.
    Normal behaviour would be the green light showing shortly at power up and the changing to red (standby).
    Does your Beolink Passive have a button on the front next to the LED?
    #65676
    ballingfisker
    SILVER Member
    yes but nothing happens when i push it. when i connect 220v it is red fore a splitsekund can hear the relay cliking and turns green.
    #65678
    Guy
    I just tested with a Passive Type 1657 SW1.4 (with the little switch).  With no connected cables (PL or ML), when powered up, the light comes on Red.  The switch has no effect, and the relay only makes a noise when I remove the power.
    Perhaps yours is faulty, or has been modified inside somehow to make it permanently ‘on’.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description available No description available No description availableNo description availableNo description availableNo description availableNo description availableNo description availableNo description available
    #65679
    ballingfisker
    SILVER Member
    okay must check it , i connect it to beosound 4 thrue masterlink , do i need the  ir eye to make i work as poweramplifier.
    #65681
    Guy
    Yes.  Usually masterlink would be used to connect the Passive in a link room, and the IR eye is then needed to control.
    If using just as an amplifier for the BS4, then connect with Powerlink (Mk2) only.
    #65682
    ballingfisker
    SILVER Member
    okay thanks , how do i se that it is MK2 powerlink.
    #65685
    ballingfisker
    SILVER Member
    found out that my powerlink cabel , there is no connection in pin. 1 and 6.
    #65687
    Guy
    In that case it’s a Mk3.  You need a fully wired Mk2, like this:  https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
    #65710
    ballingfisker
    SILVER Member
    ok have orderet 2  5m cables for my beolab penta ,trye when they arrive.
    #65711
    Guy
    If they are Beolab Penta then they have built in amplifiers and wouldn’t need the Passive.  I assume you  mean Beovox Pentas.
