Home › Forums › Product Discussion & Questions › BeoLink › beolink passiv always on
- This topic has 12 replies, 3 voices, and was last updated 10 months, 3 weeks ago by
Guy.
16 May 2025 at 23:30 #65665
ballingfisker
GOLD Membermy beolink passiv can not turne off. anyone have a tip.
Favourite Product: beosystem 3500
17 May 2025 at 07:03 #65668Madskp
GOLD MemberJust to be sure what you mean by always on you might need to clarify in what context it is used as it can be used for the following usecases:
– Link room
– amplifier for passive speakers
– converter for Masterlink (ML) to Master Control Link (MCL)
Next,how you can tell it is allways on? Is the green LED on the box allways on?
17 May 2025 at 13:35 #65673ballingfisker
GOLD Memberi want to use it as power amplifire , nothing connecet ,when i connect powercord it turns on
and i cant turn it off ,and when masterlink cable is connecet it is the same.
17 May 2025 at 14:16 #65675Madskp
GOLD MemberNot sure what could trigger this.
Normal behaviour would be the green light showing shortly at power up and the changing to red (standby).
Does your Beolink Passive have a button on the front next to the LED?
17 May 2025 at 17:26 #65676ballingfisker
GOLD Memberyes but nothing happens when i push it. when i connect 220v it is red fore a splitsekund can hear the relay cliking and turns green.
17 May 2025 at 18:36 #65678 GuyModeratorI just tested with a Passive Type 1657 SW1.4 (with the little switch). With no connected cables (PL or ML), when powered up, the light comes on Red. The switch has no effect, and the relay only makes a noise when I remove the power.
Perhaps yours is faulty, or has been modified inside somehow to make it permanently ‘on’.
17 May 2025 at 20:27 #65679ballingfisker
GOLD Memberokay must check it , i connect it to beosound 4 thrue masterlink , do i need the ir eye to make i work as poweramplifier.
17 May 2025 at 20:53 #65681 GuyModeratori connect it to beosound 4 thrue masterlink , do i need the ir eye to make i work as poweramplifier.
Yes. Usually masterlink would be used to connect the Passive in a link room, and the IR eye is then needed to control.
If using just as an amplifier for the BS4, then connect with Powerlink (Mk2) only.
17 May 2025 at 21:21 #65682ballingfisker
GOLD Memberokay thanks , how do i se that it is MK2 powerlink.
18 May 2025 at 09:27 #65685ballingfisker
GOLD Memberfound out that my powerlink cabel , there is no connection in pin. 1 and 6.
18 May 2025 at 10:37 #65687 GuyModeratorfound out that my powerlink cabel , there is no connection in pin. 1 and 6.
In that case it’s a Mk3. You need a fully wired Mk2, like this: https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
19 May 2025 at 17:17 #65710ballingfisker
GOLD Memberok have orderet 2 5m cables for my beolab penta ,trye when they arrive.
19 May 2025 at 18:08 #65711 GuyModeratorok have orderet 2 5m cables for my beolab penta ,trye when they arrive.
If they are Beolab Penta then they have built in amplifiers and wouldn’t need the Passive. I assume you mean Beovox Pentas.
