Home › Forums › Product Discussion & Questions › BeoLink › BeoLink NL/ML converters offline
- This topic has 3 replies, 2 voices, and was last updated 2 years, 10 months ago by
carolpa.
21 May 2023 at 10:06 #46770
lawrencejmcook
BRONZE MemberThis morning all three of my BeoLink NL/ML converters – each in a different room and with separate power and Ethernet connections – are offline. I can’t even open the webpage to reach them. They were working fine earlier this week.
Has anyone else experienced the same?
21 May 2023 at 12:37 #46771 carolpaBRONZE MemberThis morning all three of my BeoLink NL/ML converters – each in a different room and with separate power and Ethernet connections – are offline. I can’t even open the webpage to reach them. They were working fine earlier this week. Has anyone else experienced the same?
Several BLC’s are ONLINE and reachable.
advice: I would restart the router.
21 May 2023 at 18:26 #46772lawrencejmcook
BRONZE MemberThank you, Carolpa.
Restarting the router had no effect (still no webpage), but restarting the BL NL/ML boxes did the trick.
As a person working in IT, simply rebooting a device SHOULD BE the method of last resort. It means that one has no idea what went wrong, and you’re clutching at straws.
As a realist, rebooting should be the first resort, because it so often GETS AROUND (does not resolve) the root cause issue. (Sigh)
I looked at the logs: nothing. Wiped clean on one, and nothing between 10Oct and today on the other. And I know I used the latter one earlier this week.
Thanks for taking the time to reply, Carolpa. To me, your posts on BL NL/ML are the reference user guide for the device. Enjoy the remainder of the weekend.
Lawrence
22 May 2023 at 05:10 #46773 carolpaBRONZE MemberTo me, your posts on BL NL/ML are the reference user guide for the device. Enjoy the remainder of the weekend. Lawrence
thx, much appreciated
