Home › Forums › Product Discussion & Questions › BeoLink › Beolink Gateway will not start
- This topic has 3 replies, 3 voices, and was last updated 2 hours, 55 minutes ago by
djerik.
8 June 2025 at 07:05 #66238
christoffer.betzer
BRONZE MemberHi, I hope someone can help me with my problem.
My BLGW writes: BLGW is not ready to accept connections (503), we will retry in 5 seconds.
I have spoken to B&O support, they think there may be a port in my router that needs to be opened but I can’t really figure out which one.Attachments:
You must be logged in to view attached files.My B&O Icons:
7 July 2025 at 08:56 #66841christoffer.betzer
BRONZE MemberIs there really no one out there who can help with this problem?🫰
7 July 2025 at 14:42 #66843airmax_zh
BRONZE MemberI had this problem a couple of years ago, too. Taking off power for hours (or days) helped. I sent it to the dealer but when they plugged it in, it worked fine again. They sent it back and it worked also in my setup. Later it happened again, but after some time without power, it worked again… maybe a reset will help, too.
Finally I replaced it with a beoliving intelligence, which is way faster and reliable.
Kind regards, Rémy
3 January 2026 at 01:36 #72304djerik
BRONZE MemberI experienced that my BLGW would fail to start, and took it apart. Inside I found a micro sd card that was failing, and replaced it. This fixed my problem.
