Home › Forums › Product Discussion & Questions › BeoLink › BeoLink Gateway setup help
- This topic has 9 replies, 2 voices, and was last updated 1 year, 11 months ago by
Tim.
12 April 2024 at 07:13 #54246
Tim
BRONZE MemberHi all,
I saw a BeoLink Gateway for sale the other day and thought it might be a great idea to automate some things in our home so I bought this device without digging deeper into details. As I am normally a typical who does not like manuals and starts things I noticed after one minute that this device will be different so I downloaded the manual and started to read. And what should I say it is Beverly complicated to understand the logic behind this device.
This is why I have hope some of you guys and women can help me setting up my Gateway.
This is the setup I have
- BASEMENT
- KITCHEN
- Homekit Light Switch (Shelly)
- HomeKit Temperature Sensor
- BeoSound Emerge (Pair)
- DINING ROOM
- BeoSound Level
- LIVING ROOM
- Homekit Switch for Projector Lift
- BeoVision 7-55
- NL/ML Converter
- BeoSound Core + Record Player
- Projector
- KITCHEN
- 1st Floor
- BATHROOM
- BeoSound Emerge
- MASTER BEDROOM
- BeoSound Stage
- KIDS BEDROOM
- BeoSound Level
- BATHROOM
So I created the equivalent Areas and Zones in the Gateway and assigned the B&O stuff to the global Area.
My problems:
- When I open the BeoLiving App only the LIVING ROOM appears in the Main menu. All other other rooms are invisible.
- When I want to start B&O Radio on the Core ion the LIVING ROOM the TV is quiet and does nothing. In the B&O app and from the BeoRemote it works. TV is setup as Video Master and Core as Audio Master (connected via BeoLink NL/ML)
- How can I configure the separate Light Switches in the Gateway? The switches can be connected via the REST API
- how can I create scenes for Home Conema, Party, Sunday Brunch and Breakfast?
- How can I add PIcture to the rooms?
I think these are my questions for the moment 😉 I hope somebody can help.
13 April 2024 at 08:41 #54247 carolpaBRONZE MemberHi all, I saw a BeoLink Gateway for sale the other day and thought it might be a great idea to automate some things in our home so I bought this device without digging deeper into details. As I am normally a typical who does not like manuals and starts things I noticed after one minute that this device will be different so I downloaded the manual and started to read. And what should I say it is Beverly complicated to understand the logic behind this device. This is why I have hope some of you guys and women can help me setting up my Gateway. This is the setup I have
So I created the equivalent Areas and Zones in the Gateway and assigned the B&O stuff to the global Area. My problems:
Place your different B&0 in the correct Tones and Areas
With a Macro you can start the BV7 to play B&o Radio when you choose B&o Radio on the Core. (let me know for assistance)
create a virtual button (Resources) and make a macro to switch on and off light
if available in a Beoliving driver then it is the same principle
No. this is Beoliving feature and to my knowledge
I think these are my questions for the moment ? I hope somebody can help.
14 April 2024 at 05:35 #54248 carolpaBRONZE MemberSecond thought >
if the Beolink NL|ML Converter (BLC) is setup correctly and you give the set IR command to start the B&o radio to the BV7 then the radio should play on the tv.
so could you post the BLC settings.
14 April 2024 at 08:09 #54249 Tim
BRONZE MemberSo i just did reset the BeoLink Gateway to completely restart the whole setup.
I found some YouTube videos with some explanations and I will follow those for the first time setup.
I will reach out if I have finished the first setup (hopefully this evening).
Btw. If I press radio on my Beo4 or BeoOne in the Living Room the B&O radio from the core starts to play on the BeoVision (IR Mode 2). SO I think I probably just need a Macro that says Press Radio on Beo4 in Living Room?
16 April 2024 at 07:14 #54250 Tim
BRONZE MemberSo I managed to get the BeoSound Stage, BeoSound Core and BeoVision 7 to work.
i am now trying the light switches but I think I understood the logic.
The thing that won‘t work is the BeoSound Level and Emerge. Is the Motart Plattform not working with BeoLink? I can‘t see any source in the BeoLink Gateway from those devices and they don‘t show up in the BeoLiving App.
16 April 2024 at 18:23 #54251 carolpaBRONZE Member….. The thing that won‘t work is the BeoSound Level and Emerge. Is the Motart Plattform not working with BeoLink?
?? not to my knowledge. I still have a BLGW aside my BLI and it (the first) does show/find all my Mozart devices (BL8, BL28, BS Theatre).
Did you press the “Capture” button op the Resources page? You are sure all are connected on the same network?
16 April 2024 at 18:49 #54252 Tim
BRONZE MemberThey are seen by the BLGW but it looks like they won’t synchronise. They are on the same network and the Beolink NL/ML is also seeing the sources. So it has to do with the BLGW. Is there something I missed?
I assigned them via Ressources to the Rooms but then can’t see the individual resources in Interfaces.
17 April 2024 at 18:46 #54253 carolpaBRONZE MemberYour right, same behaviour on my BLGW
17 April 2024 at 20:29 #54254 Tim
BRONZE MemberI probably open a thicket with B&O as I think officially my Mozart speakers support BeoLink.
5 May 2024 at 18:50 #54942 Tim
BRONZE MemberSo I just got an update from B&O.
the Mozart Plattform is officially not supported by BeoLink Gateway. For the integration of the Mozart Plattform I had to upgrade to the BeoLiving Intelligence.Do we have somebody on the forum who could write an unofficial driver for the Mozart Devices? Would be a nice community project that I would be willing to support 😉
- BASEMENT
