Home › Forums › Product Discussion & Questions › BeoLink › Beolink 1000 fix (Possibly)
- This topic has 2 replies, 3 voices, and was last updated 2 years, 3 months ago by
Petang.
10 September 2022 at 11:45 #38958
Stoobie
GOLD MemberHello all,
Ages ago I posted in the old forums how to fix a Beolink 1000 that has suddenly stopped working and I thought it was worth repeating (along with a new diagram to help).
You simply take out the batteries and short the + & – terminals. A piece of wire or a paper-clip will do the trick. You won’t see or hear anything happen but it seems to reset something in the remote.
All I can say is it worked for me and at least 3 others (who confirmed this in in reply to my suggestion on the old forum post.) And a few more in the most recently archived forum when I posted again.
Another handy trick to see if any remote is sending out the IR signal, is to point it at a digital camera (mobile phone camera) and press a number button (they always output IR) and you should see the emitters blink red/purple in the camera screen. (works with all IR remotes). You may need to use the selfie camera on an iPhone.
Stoobie
30 June 2023 at 16:08 #38959Jerryege
BRONZE Membersadly this didn’t work for me so still looking for a fix. its a mark 2 beolink 1000 and it had a broken positive wire from the battery housing. once I replaced this I did get a flicker of life from the LED’s but didn’t operate my Beomaster 3500. i pressed a few more buttons and thought i’d check with the camera again and this time no flicker from the LED’s.
i have it stripped down and i’m getting around 4.5v from the batteries, just nothing from the LED’s
HELP!! 🙁
20 November 2023 at 16:25 #38960Petang
BRONZE MemberWow, thanks, this fix did the trick
- Cheers
