Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 8000: suddenly switches to Off while playing music
- This topic has 5 replies, 3 voices, and was last updated 2 years, 2 months ago by
KolfMAKER.
29 December 2023 at 03:07 #51660
KolfMAKERBRONZE MemberI have one BeoLab 8000 (serial nr. 1086 xxxx) with strange behavior.
My music source is connected via the RCA/Line input in the foot. The selector switch is set to RCA/Line.
This is what happens:
- When I start playing music, it does not immediately switch to On. Only when I set the volume on my source quite loud (appr. 85%), the BeoLab switches from Standby to On.
- After having played music, but at a lower volume level then that made the BeoLab switch On, the BeoLab 8000 switches back to Standby/Off after appr. 35 seconds.
- When playing music on the same volume level as the level that made the BeoLab switch On, it keeps playing.
Question
- Anyone, any idea what could be wrong?
31 December 2023 at 09:28 #51661auric
BRONZE MemberThe damping material has been known to degrade in Beolab 8000. Possible it has become conductive and shorting out some of the circuitry?
31 December 2023 at 12:09 #51662 KolfMAKERBRONZE MemberThnx for responding and sharing your suggestion Auric.
Yes, I know about the foamrot issue. In this I did check all PCB’s, connectors, etc. for foamrot. Some copper traces have had a ‘by-pass’ already.
What bothers me is that at high volume/signal strength the Stand-by/On switching works well. But at low volume/signal strength it doesn’t.
Do you have any other suggestions?
2 January 2024 at 05:00 #51663auric
BRONZE MemberI don’t have any additional suggestions.
My original thought was that the residue from the foam could be creating a short or adding some resistance hence higher signal goes through. But if the PCBs are all clean the fault is somewhere else.
2 January 2024 at 11:22 #51664Die_Bogener
BRONZE MemberThe copper traces of the BL8000 pcb are very thin. Acid of the foam does it’s job.
And when there are already a lot of “by-pass” repairs… ok, you will need some more.
There is not only the amplifier. There is also a round board in the foot with the LED. This board gets all the acid and debris of the foam… and is always forgotten…
2 January 2024 at 11:26 #51665 KolfMAKERBRONZE MemberThanks @Auric & @Die_Bogener
I think what I will do next is switch the PCB with the LED. I have one of a working BeoLab 8000 that I can try if that makes a difference.
