Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 8000 MK1 Foam Replacement – Original Foam Specs & Templates?
  • #123526
    Leo Axelsson
    Hey everyone,
    I’m planning to renovate a pair of Beolab 8000 MK1 speakers. From what I understand, I’ll likely need to replace the internal foam damping material since the original foam tends to deteriorate over time.
    Does anyone know the technical specifications of the original foam that Bang & Olufsen used?
    • Foam type/material
    • Density
    • Thickness
    My idea was to buy a larger foam sheet and cut the pieces myself instead of buying the pre-cut replacement kits, since those seem fairly expensive.
    Also, does anyone happen to have:
    • Templates or blueprints for the different foam pieces?
    • Measurements or diagrams for the internal foam layout?
    Any advice or tips would be greatly appreciated 🙂
    • This topic was modified 5 months, 3 weeks ago by Leo Axelsson.
    #123529
    skolesen
    GOLD Member
    Hi Leo,
    I know this dosn’t answer your question, but take a look here:
    Set of Damping Foam and Cabinet sealing for Pair of Beolab 8000
    /steffen
