Home Forums Product Discussion & Questions BeoLab Beolab 8000 distance installation
  • #42728
    dueno
    GOLD Member
    hi,
    is there a recommanded distance between two beolab 8000 in stereo. Which is the minimal and maximal distance? I saw on homecinema forum a distance between 2-4m for front loudspeaker.
    My earing position is at 5 meters from the loudspeakers(but I have not the possibility of 5 meters between the beolab 8000).
    thanks.
    Millemis
    If you have video source/tv in between or just want to have a funtioning stereo imaging from where you sit, the speakers should not be too far apart.
    The further they are apart the harder it will be to find a sweet spot for listening.
    If you have a video source/tv a center channel will help.
    #42730
    billb
    GOLD Member
    I have mine 2.5m apart and my seating position is 3.5m away. In a perfect world my seating position would be closer. As it is, I have excellent sound stage imaging in this setup which is strictly 2 channel stereo.
    Bill
