Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8000
- This topic has 3 replies, 2 voices, and was last updated 4 years, 3 months ago by
KolfMAKER.
15 May 2022 at 01:37 #34828
Ckbrookes
BRONZE MemberHi All
I recently re foamed my 8000’s all good great improvment But although I can hear the speaker click on and off the green light stays on ? the speaker is working ? any ideas
Kind regards
Colin
15 May 2022 at 13:42 #34829 KolfMAKERBRONZE MemberI assume you took the old foam out and that you had to clean the remains from foam rot?
If that is the case, you can check if some of the copper traces on the PSU PCB have been damaged by the foam rot. Sometimes you need a magnifying glas to see it, but then you might detect copper traces partly ‘eaten away’ by foam rot. If you have such a thing, you can solder a wire as a kind of by-pass.
Also check if there is still foam rot remains on connectors or components. And check if there are components that are damaged, like for instance capacitors that look puffy.
What is the serial number / production year?
15 May 2022 at 13:51 #34830Ckbrookes
BRONZE MemberHi
I can’t give the serial as I put mk2 innards into a mk1 chassis every think was fine till a I took them apart again to re form ?
Col
15 May 2022 at 17:04 #34831 KolfMAKERBRONZE MemberSo if I understand right, you put an MK2 amp in a MK1 housing right?
