Home › Forums › Product Discussion & Questions › BeoLab › Beolab 7-2 as a B&O multiroom speaker?
- This topic has 6 replies, 2 voices, and was last updated 1 year, 1 month ago by
Guy.
9 February 2025 at 07:20 #63598
boj
BRONZE MemberDear Forum.
Is it possible to use a beolab 7-2 as a B&O multiroom speaker via the B&O app, and at the same time as a tv speaker? Which options do I have?As is I am using a hdmi arc extractor between my LG and the Beolab. It could be sweet also to use the speaker in a multiroom setup.
Thanks in advance.
Bo
9 February 2025 at 10:53 #63607 GuyModeratorI am not sure how you are triggering the Beolab at the moment – do you have a separate (maybe USB) 5V supply to turn it on?
One solution could be to add a Beosound Essence Mk2. Connect your TV hdmi arc extractor output to the Essence’s auto sensing line input, and connect the Beolab to the Essence PL output.
9 February 2025 at 11:10 #63610boj
BRONZE MemberHi Guy.
Does the essence have a wifi option? I have no lan.
9 February 2025 at 12:10 #63614 GuyModeratorDoes the essence have a wifi option?
Yes it will connect to wifi so you don’t have to use a wired network.
If you do get an Essence, make sure that you get a Mk2 which (unlike the Mk1) has support for NL/Beolink Multiroom.
25 February 2025 at 14:41 #64027boj
thank You for responding. Which cable should I Shop for, if I only want my Beolab 7 to be connected with beosound Essence?
Boj
25 February 2025 at 16:01 #64028 GuyModeratorYou should be fine with the following cable from one of the Essence’s RJ45 powerlink outputs to the BeoLab 7-2 Powerlink input, but please double check with Steve (at Sounds Heavenly) before ordering: https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m
(My understanding is that the BeoLab 7-2 triggers on/off from Powerlink pin 4, in which case the above cable should work fine.)
25 February 2025 at 16:21 #64029 GuyModeratorOne additional thought about your setup: If you are indeed using the Essence line-in for your TV sound input (from your hdmi arc extractor), then you will have to go into the Essence setup menu, go to the ‘Sound’, ‘Line-In’ setting and tick the little check box to ‘disable delay’.
The little note above the ‘disable delay’ box explains why you need to do this as follows: Sound from line-In connected sources is delayed in a Multiroom system. Therefore, when used with video content, picture and sound is not synchronized. The delay can be disabled, but sound from line-in can then not be distributed.
