Home › Forums › Product Discussion & Questions › BeoLab › beolab 6000 repair with end of 3500
- This topic has 3 replies, 3 voices, and was last updated 3 years, 2 months ago by
filipbrugge.
13 January 2023 at 01:24 #42762
filipbrugge
BRONZE Memberhello, my beolab 6000 has a scratch.
As I have beolab 3500 just lying here, can I swap one of the ends of the 3500 and use as a top of the 6000 ?
13 January 2023 at 14:19 #42763 matador
ModeratorMy god, “a beolab 3500 just lying here…”, criminal. 😀
Service manual show different part number but the look like very close with the same groove and have the same way of mounting, two prongs and a screw in the middle.
If you have booth at hand, I would take measurements and try my luck.
13 January 2023 at 15:10 #42764 KolfMAKERBRONZE MemberHi Filipbrugge,
Do you have a deep scratch?
I have experimented with a chrome type of repair marker. It worked quite well to cover the deep scratch damages.
14 January 2023 at 09:52 #42765filipbrugge
BRONZE Memberthank you for the reply, the 6000 has a little dent on the side – I will try to swap them and keep both working 😉
