Home › Forums › Product Discussion & Questions › BeoLab › Beolab 5 – Help needed
- This topic has 6 replies, 3 voices, and was last updated 3 years, 2 months ago by
YannChris.
12 January 2023 at 06:35 #42731
YannChrisGOLD MemberHello Beoworlders,
One of my BL5 does not activate when I switch-on a source.
The red light is on and flashes when I tap the tactile area.
Power cycle does not change anything.
Is there a way to hard-reset the speaker?
I have been told that BL5 cannot be fixed anymore by dealers and that chassis have to be sent to Struer for repair (with no idea of delay).
I am very surprised with this, can anybody confirm?
Thanks by advance and kind regards,
Yann.
12 January 2023 at 19:08 #42732NQVHNWI
BRONZE MemberHi,
sorry to be a bearer of bad news, but one of the possibilities of this type of behaviour may be a problem with the EPROM/ chassis module.
Did the failure occur after playing very loud or bassy music? If so, the fault could be overheating, but then not resetting itself.
Have you also tried doing a room calibration? That may “wake” the unit up??
Best of luck
12 January 2023 at 19:13 #42733 YannChrisGOLD MemberHi,
Thanks for your reply.
Yesterday I watched TV at normal level, the failure occured today when I switched-on the TV.
Nothing happpens when I do a room calibration.
Yann?
13 January 2023 at 13:38 #42734Donot
BRONZE MemberDo you have check the cables?
if the red light is on than must your cable not have connected, or have you change the menu audio ?
if you lab 5 is defect than blinking the red light,
hardreset is press ca 20 sec the key at the top
you can also unplug the speaker for 5 minuteshardreset delete also your calibration details
13 January 2023 at 17:05 #42735 YannChrisGOLD MemberThanks Donot,
Yes, I checked the cables and no, I didn’t change anything in the menu.
The red light is solid. It only blinks if I touch the tactile zone.
I performed the hard reset: the red light blinked as long as I touch the tactile zone. After a moment, it stopped blinking.
Then performed a power-cycle.
Nothing changed.
I come to the conclusion that the Lab5 is faulty and my question about the repair process makes sense.
Can anybody confirm, or inform, that chassis have now to be sent to Struer for repair (with no indication of delay…)?
Kind regards,
Yann.
20 January 2023 at 09:42 #42736Donot
BRONZE MemberCall your local B&O dealer
hi have laptop and cable to look inside the software about the lab5.
it is possible that the software it indicates what is defective.
repair is only possible by a dealer, you cannot send it yourself, at my cost repair 900 euros by exchanging the chassis (the amplifiers) it seems that b&o has now opted for repair, so your chassis is now being tested and the parts dell replace one that is defective, this reduces the starting price to at least 500 euros.
20 January 2023 at 10:22 #42737 YannChrisGOLD MemberThank you, Donot.
