Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 4000 Stands. Disassembly
- This topic has 5 replies, 4 voices, and was last updated 1 year, 3 months ago by
Glitch.
21 October 2024 at 16:49 #60345
h1npw
BRONZE MemberHi
Can anyone tell me how to separate the poles from the bases?? One would have thought they would just unscrew but I can’t budge them!
Cheers
Nigel
21 October 2024 at 22:36 #60352 GuyModeratorI have the same problem! I have definitely read somewhere on Beoworld that they unscrew but can’t find the reference; I think it was mentioned by Lee (former site owner). I have tried several times (every house move) but cannot get them apart. Maybe WD40, or application of cold/heat, or percussive shock??? Good luck!!
22 October 2024 at 00:29 #60354billbriscoe
GOLD MemberHi,
I just unpacked my set from the original B&O packaging and I can confirm that the poles are simply screwed into the bases. As Guy suggests, WD40 (overnight) might help.
Bill
22 October 2024 at 13:52 #60363h1npw
BRONZE MemberThanks both for your replies
Bill – they’re not left hand threads are they?
23 October 2024 at 00:09 #60387billbriscoe
GOLD MemberNo they are not, they screw in clockwise (right hand) and screw out counterclockwise (left hand).
The aluminum poles are threaded and screw into the threaded iron base. WD40 for a few days may be necessary to remove them without damaging the aluminum threads. I would apply from both the top and bottom. As Guy mentioned, heat may help (applied to the iron base from the bottom).
Take your time and let the WD40 do a lot of the work so you don’t damaged the aluminum threads. Applying some type of anti-seize thread compound would be a good idea when re-assembling.
24 October 2024 at 13:34 #60418Glitch
BRONZE MemberI agree with much of the advice given by others. Also, consider heating the iron base (and indirectly the aluminum tube), then applying something like circuit freeze to the inside of the tube. The idea is to drive the maximum amount of thermal expansion difference between the parts. The high thermal conductivity of the aluminum should help here. Combine this with the penetrating oil and run multiple thermal cycles.
There may be so much galvanic corrosion in the threads that they may not come apart without damage. This may be a case where it is better to just leave them assembled.
If you are obsessed with getting it apart and all else fails, the tubes could be cut off and everything rethreaded. The stands would be a bit shorter, but you would be able to reset the clock on the corrosion cycle ;-).
Glitch
