Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 not responding to Beo4
- This topic has 3 replies, 3 voices, and was last updated 2 years, 5 months ago by
Madskp.
21 August 2023 at 07:46 #48361
andersojohansson
BRONZE MemberI have a system consisting of Beosound 3000, a pair of Beolab 3, a sub Beolab 11 and a linkspeaker Beolab 3500. I use a Beo4 to control the units.
However, the Beolab 3500 is not responding to the remote anymore. I do not have a clue whether it is the Beolab 3500, the Beo 4 or the master link cable that is malfunctioning.
Does anybody have ideas about what could be the problem?
/Anders
21 August 2023 at 08:11 #48362 Guy
ModeratorGood morning and welcome to Beoworld!
Perhaps the Beolab 3500 is in L.OPT 0, which is a setting where it will not respond to IR commands. To resolve this, turn the system to to standby/off. Then, in the BL3500 room using the Beo4, press the POWER button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show L.OPT. Then press 6. The screen on the Beolab should then show the option that you have selected. Then try the remote again.
22 August 2023 at 11:47 #48363andersojohansson
BRONZE MemberThanks for the reply. I have now tried it and the Beolab 3500 shows “Option 6” on its display for a while. However, I still cannot wake it up from standby with the remote.
22 August 2023 at 11:59 #48364Madskp
GOLD MemberTry pressing Menu, 0, 9, GO to see if Masterlink is on or off.
If it is off you can change the setting with up or down arrows and accept with GO
You can also try to see if there is a Masterlink error by pressing Menu, 0, 2, GO.
This will either show NO ML, ML ON or ML error 1-4
