Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 MK1 MCL MENU 0 4 GO HELP
- This topic has 18 replies, 8 voices, and was last updated 2 years, 7 months ago by
matador.
25 August 2022 at 09:59 #38580
Jg1976
BRONZE MemberHi, I need help.
Trying to activate my BEOLAB 3500 MK1 and the MCL socket listen via 3,5mm cable.
I can not get it to respond on MENY 0 4 GO, or MENY MENY 0 4 GO on Beo4.
What is wrong or what am I doing wrong?
25 August 2022 at 11:41 #38581 Guy
ModeratorPerhaps the BL3500 is in L.OPT 0 where it doesn’t respond to IR codes.
To put it in L.OPT 2:
- If using Be0link 1000 remote, press LINK 2 STORE.
- If using Beo4, press the POWER (red) button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show L.OPT. Then press 2.
Now try MENU MENU 04 GO again.
25 August 2022 at 11:41 #38582 KolfMAKERBRONZE MemberHi Jg1976.
You mention you can’t activate your BeoLab 3500 MK1 to listen to the MCL socket.
What does your display show after pressing ‘Menu > Menu > 0 > 4 > Go’ ? (This sequence should switch the BeoLab 3500 to the MCL input)
You could also check your BeoLab 3500 in ‘Test mode’. To do this press ‘Menu > 0 > 2 > Go’
And then check what you see in the display:- ML OK = Master Link Connection is OK
- NO ML = Master Link is not connected
- Error 1 = Address configuration not possible
- Error 2 = Master Link data pulled low
- Error 3 = Master Link data pulled high
- Error 4 = Data collision on Master Link
If you see ‘ML OK’, the BeoLab functions properly, and your cable will probably be wrong. Connections and pins used might be the problem.
If you are handy yourself, you can make such cable yourself. Lots of info on this forum.
You can also ask @Steve of SoundsHeavenly to help you with the right cable.Location: The Netherlands
25 August 2022 at 12:20 #38583 Jg1976
BRONZE MemberThank you for all help!
The Beosound 3500 is still stone dead. Nothing happen.. It is now in L-opt 2 (thank you Guy) I have also tried all other L.opt.
KolfMAKER, nothing happens when I press MENU 0 4 GO. Nothing happens when I press MENU 0 2 GO..
Maybe it is broken?
25 August 2022 at 12:38 #38584 Jg1976
BRONZE MemberOk, so I connected it to my normal Masterlink. It works. But only when press ON on the Beosound 3500 panel and not via BEO4 so it seems to be a remote control issue..
It won’t respond to any command so it definately look to be an L-opt 0-issue..
I can not either change L-option due to the remote does not respond..
Are there any way to reset the unit without the remote?
25 August 2022 at 12:48 #38585 KolfMAKERBRONZE MemberConcerning your remote, so it is a BEO4?
Does the display of the BEO4 show responses when you press buttons?
Maybe stupid, but did you check the batteries?Location: The Netherlands
25 August 2022 at 12:52 #38586 Jg1976
BRONZE MemberYes, I have 9 of them or more so I tried several that also work in other rooms. So it looks to be an IR-issue on the Beosound 3500.. How to solve I do not know..
25 August 2022 at 12:56 #38587 Jg1976
BRONZE MemberI find this article online:
“Beolab 3500 nightmare!!
Recently purchased a beolab 3500 with the intention to use it as a stand alone sepaker.It responds fine to the mute and timer buttons however doesn’t seem to respond to a controller I know is working.Have tried putting it into option 6 with no luck.somone please help!
Answer: It seems like this is a common issue my 3500 died this way too. Tried every reset command but the only way to fix this error is to change the entire IR board. But I didn‘t find any boards online and I think repair from B&O would be very expensive. I ended up buying a used 3500 for 100€ and be hold the old one for spare parts”
25 August 2022 at 14:04 #38588 KolfMAKERBRONZE MemberVery unfortunate to hear that, it is such a beautiful product.
I just ha d a look in the service manual, and noticed that the power transformers are near the PCB’s that are in the middle. Of course that are cooling elements. But I can imagine that high temperatures in such small casing, after years of use, do have impact in the electronics.
What I am saying, is that the soldering of the IR-PCB might suffer from loose connections or cracks in the soldering. If you have nothing to loose, you could try to check that, and do some reflowing of the soldering with an soldering iron, or the ‘oven trick’.
25 August 2022 at 14:26 #38589 Jg1976
BRONZE MemberThank you KolfMAKER..
Maybe I will give that a try once I have the time..
Appreciate all the help..
25 August 2022 at 18:39 #38590 Keith SaundersBRONZE MemberI think the question I would ask is it really a Mark 1 Beolab 3500 or is it a LCS9000 which looks exactly the same, but the early versions had modified software?
Check the B&O label in the back..
25 August 2022 at 19:23 #38591 Jg1976
BRONZE MemberThank you Keith.
It is definately a 3500 mk1.. So the label says.
15 August 2023 at 16:00 #38592AndyG77
BRONZE MemberHello,
I’m very new to owning B&O and just bought few products after been very impressed by the B&O sound in my BMW F16. My Beosound 6000 works flawlessly, but I have problem with 3500.
Just wondering if there was any luck with the above? do you finally made it work?
I have exactly same problem- have BEO4 and Beolab3500 MK1, with cable fromSteve, but I cannot turn it on
I press LIST and select SPEAKER on the remote and then trying to do the MENU 04GO
shall I connect/pair the remote to the speaker somehow?
Anything I press on rem one immediately throw me to the “TV” on the display.
Any help would be welcome.
15 August 2023 at 17:12 #38593RaMaBo
GOLD MemberHi,
try any of the audio sources on the BEO4 and then in front of the Beolab 3500 press
15 August 2023 at 19:07 #38594AndyG77
BRONZE MemberUnfortunately it does not react on any buttons.
How to check if it actually sees remote?
15 August 2023 at 19:18 #38595AndyG77
BRONZE MemberI seen somewhere on the forum that beolink converter 1611 might be a solution?
can you please educate me a bit what is this converter for and how does it works. Also would it help in my situation?
15 August 2023 at 20:31 #38596Madskp
GOLD MemberUnfortunately it does not react on any buttons. How to check if it actually sees remote?
It could be that it is in option 0 (not reacting to IR commands) or option 4 (only reacting to link commands).
Try to set it to option 2 as described in Guys post earlier in this thread https://forum.beoworld.org/forums/topic/beolab-3500-mk1-mcl-menu-0-4-go-help/#post-8004
15 August 2023 at 20:36 #38597Madskp
GOLD MemberI seen somewhere on the forum that beolink converter 1611 might be a solution? can you please educate me a bit what is this converter for and how does it works. Also would it help in my situation?
I would reccomend that you take a look at this post https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/4/#post-14017
The 1611 converter can be used to make 2 inputs controlled by either audio or video commands.
In my opinion its a much better solution than the Menu, 0, 4, GO because its easier to activate and you can use the volume control from the BEO4 remote which is not possible in the other wayLocation: Denmark
15 August 2023 at 21:00 #38598 matador
ModeratorUnfortunately it does not react on any buttons.
It seems to be a common IR board issue. The Beolab do not “see” the IR beam.
I think I’ve read somewhere that the solution it’s the usual two caps replacement, easy, but the problem is accessing the board that implies a deep dismantling IIRC.I seen somewhere on the forum that beolink converter 1611 might be a solution?
It will not be a solution to your IR problem but it will make the use of your BL3500 more convenient (once you solved the IR problem). The topic is well documented somewhere in the forum. Do a search with 1611.
