Home › Forums › Product Discussion & Questions › BeoLab › BeoLink Converter 1611 Innovative Configurations
- This topic has 502 replies, 20 voices, and was last updated 2 months, 4 weeks ago by
Madskp.
17 November 2024 at 20:09 #60990
Tobias Toft
BRONZE MemberHey folks. I’ve been following this thread closely (thank you!), and decided to give the 1611 a shot as a way to enable more input sources on my Beosound 4. Here’s what I got so far:
My Beosound 4 is set up as an audio master in Option 2, to enable the video inputs on the 1611. If I press any video source on the Beo 4 directed at my BS4, it works as expected, and it starts playing audio from the Wiim Pro via the 1611. Same with the Beolab 3500. However, I think my BS4 has a weird bug:
As soon as I adjust the volume on the BS4, either via the front panel or the Beo 4, the red stand by led comes on and the display freezes on “Volume XX”. I can turn the unit on and off, it responds to remote commands, and generally does what it needs to do, but the display never updates. The only thing that will refresh the display is if I press “Menu” on the front panel, which will allow me to traverse the menu system. However, when I exit out of the menu it clears the display and stays blank when I turn the unit on, off, select sources, adjust volume, etc. Unplugging the power and plugging it back will reset things, but as soon as I adjust the volume on a video source it freezes up again.
Has anybody seen this? Is it a known software bug on the early versions of the Beosound 4?
PS. Apologies if this is too off-topic for this thread, happy to start a new one if that’s preferred!
18 November 2024 at 17:16 #61022Madskp
GOLD MemberHey folks. I’ve been following this thread closely (thank you!),
Great to hear that the thread is usefull 🙂
As soon as I adjust the volume on the BS4, either via the front panel or the Beo 4, the red stand by led comes on and the display freezes on “Volume XX”. I can turn the unit on and off, it responds to remote commands, and generally does what it needs to do, but the display never updates. The only thing that will refresh the display is if I press “Menu” on the front panel, which will allow me to traverse the menu system. However, when I exit out of the menu it clears the display and stays blank when I turn the unit on, off, select sources, adjust volume, etc. Unplugging the power and plugging it back will reset things, but as soon as I adjust the volume on a video source it freezes up again. Has anybody seen this? Is it a known software bug on the early versions of the Beosound 4?
I can’t say that I have much experience with the BS4. However I would suggest that you try to isolate the problem by removing the ML connection to for example the 1611 and the MLGW to see if the problem persist. Hope this is helpfull
GOLD MemberWas a little curious about the BLC 1610 so I had to open one up to see what is ticking inside:
All pins in use on the two ML connectors are wired in parallel, so just kind of an internal junction box. What is unusual with the ML connectors is that pin 3, 4, 5, 6 and 12 is all connected where pin 12 is supply voltage +, and most of the others are normally no used. This however explains where this box is getting power as the same pins are supplying +12V on the diagram for the AV9000
One other curiosity is that next to the external 1-2-3 switch is an internal switch with 2 positions:
These are named:
- Central 1610
- Local 1611
Not really sure if that means it will function like a 1611 if it is in that position. Might do some more testing around that at a later point.
I found a MCL service manual on Archive.org that besides all the MCL2 stuff (also for the newer MCL2AV) also has the service documentation for the 1610 AV9000 Audio kit.
This reveals what both the internal and the external the switch do:
However a little disapointing for those settings where it is for future use.
With this knowlede I had to do a test to see if I could get it working. I have tried with my BC6-23 as Videomaster (V.opt 2) and my BC9300 as Audio system in A.Opt 0 and the 1610 with the external switch in position 3.
No result I could not get the TV to start the BC9300. Also tried to add more power from an external 12V power supply as the 1610 use som extra pins in the Masterlink connector for power, but still no result. I tried with 2 of the 1610 boxes I have with no luck.
And just to verifiy that the TV and the beocenter worked togheter I tested the connection between them with a Beolink Conveter 1614 in between and that worked flawlessly. I guess the 1610 boxes probably either only will work with the AV9000 ore are defective.
