Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3 with PC – Best solution?
- This topic has 1 reply, 2 voices, and was last updated 4 months, 2 weeks ago by
Millemis.
8 May 2026 at 21:38 #123520
Jacob Terp Christensen
BRONZE MemberSo I just acquired a set of BL3’s that I want to use with my PC.
I’ve seen post with people suggesting the cable from Sounds Heavenly, but a local supplier makes an adaptor that also has a USB trigger.
So what is the best solution?
8 May 2026 at 22:08 #123521 Millemis
BRONZE MemberHej Jacob
From your name I assume that you are located in Denmark.
The cable solution that you mention probably is from A/V Connection.
That is a trusted solution, that has existed for many years.
I’d say….go local.Please report your findings here…might help others.
P. S.
Should you however be in the UK….go for Steve’s solution.MM
