Home Forums For Sale & Wanted For Sale BeoLab 3 wall mounts
  • #124232
    willem.van der klugt
    Two-piece wall mount system for B&O Beolab 3 speakers featuring integrated cable management. The modular design allows easy installation with a wall-mounted base piece and a sliding speaker bracket. Includes cable routing channels for clean wire management.
    Remember to route cables through the first piece before securing to the wall. Be careful not to damage the cables while sliding the second piece on. There is a cable channel in the second sliding part, gently pull the cables out while sliding down. Cables must be routed through the hole before sliding down.
    Because of the sliding design, the wall must be relatively straight, and be without large bumps and voids.
    The mounts are made of carbon fiber a super strong material which can easily carry the small weight of the BeoLab 3’s.
    Please note that the mounting screws are NOT included.
    Price €37,50 excluding postage from The Netherlands
    I have 2 pair wall mounts for sale, price mentioned is for one pair.
    Mitul Patel
    Hi Willem,
    I would be interested in the Beolab 3 wall brackets.
    Kind regards
    Mitul
