Home › Forums › For Sale & Wanted › For Sale › BeoLab 3 wall mounts
- This topic has 2 replies, 2 voices, and was last updated 3 months, 3 weeks ago by
mitul.patel.
27 June 2026 at 15:09 #124232
willem van der klugt
BRONZE MemberTwo-piece wall mount system for B&O Beolab 3 speakers featuring integrated cable management. The modular design allows easy installation with a wall-mounted base piece and a sliding speaker bracket. Includes cable routing channels for clean wire management.
Remember to route cables through the first piece before securing to the wall. Be careful not to damage the cables while sliding the second piece on. There is a cable channel in the second sliding part, gently pull the cables out while sliding down. Cables must be routed through the hole before sliding down.
Because of the sliding design, the wall must be relatively straight, and be without large bumps and voids.
The mounts are made of carbon fiber a super strong material which can easily carry the small weight of the BeoLab 3’s.
Please note that the mounting screws are NOT included.
Price €37,50 excluding postage from The Netherlands
I have 2 pair wall mounts for sale, price mentioned is for one pair.
You must be logged in to view attached files.Location: The Netherlands
28 June 2026 at 18:36 #124264mitul.patel
BRONZE MemberHi Willem,
I would be interested in the Beolab 3 wall brackets.
Kind regards
Mitul
Favourite Product: Beolab 3000
29 June 2026 at 20:18 #124285mitul.patel
BRONZE Member -
