Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3 for PC
- This topic has 6 replies, 4 voices, and was last updated 4 years ago by
Steve at Sounds Heavenly.
28 March 2022 at 02:38 #33593
Emilos88
BRONZE MemberSo Beolab 3 are at a very low price now, so I am thinking of adding them to my PC setup.
But I hope you can help a bit, as I know that the blacks can get a bit sticky in the surface. Does the white do that?
And how will you recommend plugging them to a PC? can I just get a direct cable? or should I use something like the Core or something cheaper?
28 March 2022 at 14:43 #33594Emilos88
BRONZE MemberI guess I just need these:
Anyone know about the color?
28 March 2022 at 15:28 #33595 9_LEEBRONZE MemberThe white is a painted finish and doesn’t go sticky. It also looks really nice, but white seems to be going out of fashion these days.
It’s just the black and the grey which suffer from the stickiness (which cannot be remedied, believe me). All other colours are fine as they’re painted as opposed to the soft-touch finish which breaks down…
Steve is your man for cables on here!
28 March 2022 at 18:53 #33596 Steve at Sounds HeavenlyGOLD MemberHi,
Yes, that is the cable you need, set both speakers to Line mode and they will work straight from the PC with volume control from the PC. Any questions, please feel free to get in touch via my sponsor link at the foot of the page and I will be happy to help!
Kind regards, Steve.
28 March 2022 at 23:15 #33597Peter the Biker
GOLD MemberThat’s my way …
(Looks a little bit messy, but it works. But before you pull the “headphone jack” switch off the mains for the BeoLab 3.
1 April 2022 at 08:03 #33598Emilos88
BRONZE MemberHallo Steve I want to buy a 3M, but it says sold out.
Actully I need a 2M, can you make that one for me?
1 April 2022 at 08:11 #33599 Steve at Sounds HeavenlyGOLD MemberHi,
Please can you get in touch directly at https://soundsheavenly.com for any specific order questions? I will then be happy to help.
