Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 18 + beoconnect with WISA
- This topic has 2 replies, 2 voices, and was last updated 1 year, 5 months ago by
20cen.
28 October 2024 at 13:37 #60505
20cen
BRONZE MemberHi all,
is there a a way to make one of this 2 setup:
– connect 2 beolab 18 with a beoconnect with WISA
– or connect 1 beolab 18 with a beoconnect with powerlink, and the second beolab 18 with WISA connected to the first beolab 18
thanks for your help
28 October 2024 at 20:46 #60523DT79
BRONZE MemberUnfortunately not. The Beoconnect Core doesn’t have Wisa built in. You could connect the Beoconnect Core to a Transmitter 1 and then connect the BL18s via Wisa, however the downside of that approach is that you lose the ability to optimise the output of the Beoconnect Core to the BL18s.You can connect one BL18 to the Beoconnect core via Powerlink, but then you need to connect the first BL18 to the second via Powerlink as well.Hi all, is there a a way to make one of this 2 setup: – connect 2 beolab 18 with a beoconnect with WISA – or connect 1 beolab 18 with a beoconnect with powerlink, and the second beolab 18 with WISA connected to the first beolab 18 thanks for your help
29 October 2024 at 10:14 #6055720cen
BRONZE MemberOk thanks for your answer 🙂
