Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 11 issue
- This topic has 4 replies, 3 voices, and was last updated 2 years, 4 months ago by
jonniebravo1963.
3 November 2023 at 10:49 #50083
jonniebravo1963
BRONZE MemberHi all,
Would appreciate any thoughts.
Lab 11 had a low humming sound, no real sound other than that and green light stable. Stripped down and appeared to be coming from pcb 35 ICE amp. Swapped this for a new one and all working for 3 hours then same thing has occurred. Hoping this hasn’t damaged new module but struggling to think why this would happen.
Cheers
Jonnie
3 November 2023 at 14:54 #50084LukeS
BRONZE MemberI’m sure you’ve already considered this, but are you using the correct powerlink cable version? This will definitely cause a hum if you use the incorrect version
4 November 2023 at 11:37 #50085jonniebravo1963
BRONZE MemberYes Luke MK3 and been using it for 10 years or so..
8 November 2023 at 09:45 #50086Beojuhl
BRONZE MemberTry another cable first
8 November 2023 at 10:11 #50087jonniebravo1963
BRONZE Member1st thing I did, brand new cable and same problem
