Home › Forums › Product Discussion & Questions › BeoLab › Beolab 10 sound to loud issue
- This topic has 0 replies, 1 voice, and was last updated 3 months, 2 weeks ago by
Hubert Dula.
1 July 2026 at 17:30 #124334
Hubert Dula
BRONZE MemberGood day I am running a setup as followed: A wifi/spotify receiver with an aux output to the Beomaster 4500 (echodot 2)
-> two pentas mk1s connected via 2 pin cables left and right (non active)
->two beolab 5000 wall speakers (active) connected between each other with an original powerlink cable (they are active chosen for left and right) and one of them connected to the beomaster 4500
-> a beolab 10 speaker wall mounted connected with a thin powerlink cable (not sure if original or knockoff) connected to the beomaster 4500
-> in result all inputs are taken -> 1x left 2pin 1x right 2pin input / 2x powerlink inputthe issue: the beolab speaker is around 2x louder compared to the other speakers as a total beginner it maybe be simple but… is it possible to somehow reduce the beolab 10 sound output?
I was trying to do this with the beolink1000 remote by changing the left and right balance but this also affects the others speakers.
Some manual tinkering?
Best thing that would be is some sort of cable with a volume dial like in the old school cheap headphones we used to run.
In addition is there a wall height designated for both the beolab 10 and the beomaster 5000 (yes i tried to google this but nothing valuable came up) Do we aim for the speakers (membrane) to be at ear height when sitting?
Thank you for taking the time to read and the help. Cheers
This topic was modified 3 months, 2 weeks ago by
Hubert Dula.
