Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD 7000 laser assembly moves violently
- This topic has 2 replies, 2 voices, and was last updated 1 month, 3 weeks ago by
kees.de groot.
18 August 2026 at 15:56 #125054
kees.de groot
BRONZE MemberHello all!
I’ve recently acquired a Beogram CD 7000 (together with the BM 7000), and have revised the player with a new 47 µF cap and suspensions, bushings, etc. It has been working gloriously ever since—but when the player starts reading, the laser assembly is knocked violently towards the centre with an audible ‘knock’ sound. The same happens when the laser stops reading from any position. It seems that when it loses power it gets a jolt of current, slamming the laser assembly to its maximum or minimum position. I have the feeling this has to do with a/multiple capacitor(s) failing. Could someone direct me to which one(s) to replace, and whether it then needs re-adjustment?
Thank you in advance, I appreciate any insights!
—Kees
30 August 2026 at 08:34 #125296Dillen
ModeratorDid you use the right brand and type of capacitor for C2103?
Not any old capacitor will work here, as we have discussed previously on these pages.Martin
30 August 2026 at 13:22 #125308kees.de groot
BRONZE MemberI’ve yesterday replaced all caps on the servo board and the knocking sound is much less. Seems like it may fix itself over time? I’ve also replaced the new 47 μF Vishay cap I had placed with the 33 μF one in the kit. I noticed no difference with the 47 or 33 μF.
