Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5500: Arm “sliding” across record
- This topic has 5 replies, 3 voices, and was last updated 3 years, 8 months ago by
TimeBandit.
26 July 2022 at 02:52 #36373
TimeBandit
BRONZE MemberI seem to recall others experiencing what I’m about to describe, but I can’t find the threads. . . .
When I press Play, the arm sets down correctly, but then begins sliding across the record toward the center spindle. It’s as if it doesn’t have the correct tracking force, even though it does. Thoughts?
26 July 2022 at 04:24 #36376TimeBandit
BRONZE MemberSo I did find one other instance of the same issue. Unfortunately, no resolution was ever reached.
https://archivedforum.beoworld.org/forums/t/31724.aspx
26 July 2022 at 15:05 #36374 isthatthebeotimeBRONZE MemberJust a quick question is the plastic guard cap down on the cartridge? If not flicked up fully this can cause it to just skip across a record!
26 July 2022 at 15:22 #36375TimeBandit
BRONZE MemberWorth asking, because stupid stuff happens, but yes, the stylus guard is up.
26 July 2022 at 16:29 #36377Die_Bogener
BRONZE MemberIs the MMC ok?
Sometimes the stylus is broken and the needle is bent upwards or even complete missing… then the MMC case slides over the record…
26 July 2022 at 16:34 #36378TimeBandit
BRONZE MemberYep, I just about to post that I looked more closely at my cartridge, and sure enough the stylus has broken off. Oh well.
