Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5005 needle biasing to outside of record
- This topic has 7 replies, 2 voices, and was last updated 5 months, 2 weeks ago by
James Vinnington.
30 April 2026 at 00:24 #123410
James Vinnington
BRONZE Membervideo here: https://youtube.com/shorts/FKRchcY8Zj8?si=4CIMb57X1uDK2Dre
Hello everyone,
I was given a Beogram 5005 that seems to work quite well. However one issue I am having is that when the stylus is first placed on the record, the stylus seems to “collapse” or be dragged to the right of the cartridge toward the outside of the record. This causes audible distortion. The tone arm seems to track pretty decently, it’s perhaps a little out of parallel, but I’m not sure what the issue may be. When this happens, I can very gently push the tone arm to the outside of the record, without skipping the groove, and the issue is resolved until the next time the tone arm is raised and lowered.
I am aware that tone arm parallelism can be adjusted with screw C. I’ve also read some people who claim that the issue is that the tone arm advance shutter needs to be shifted forward or backward, basically leading or lagging the tone arm advance.
If I had to guess, I’d say that it looks like the tone arm wants to rest ahead of the groove, causing the stylus to deform to the right side (from the video perspective).
any thoughts would be welcome here!
You must be logged in to view attached files.30 April 2026 at 03:46 #123414 Mark-sfBRONZE MemberI would first check to make sure that at rest, cued up, the stylus is centered. If it is, then the shutter is misadjusted. You may see evidence of that when the arm is cued down, in that the tonearm moves a bit laterally instead of dropping straight down. When the belt is off, and the arm is cued down on a record, it should drop straight and then not move for 2-3 revolutions of the record.
30 April 2026 at 11:09 #123416James Vinnington
BRONZE MemberFrom what I can tell, it seems that the stylus has a slight angle to the right in the photo below while queued up. I suppose that indicates damage?
You must be logged in to view attached files.30 April 2026 at 19:23 #123423 Mark-sfBRONZE MemberI’m afraid it does. You are not likely to be able to get it rebuilt, but Soundsmith sells an SMMC4 for $230 as a replacement. They are reputable.
30 April 2026 at 22:34 #123426James Vinnington
BRONZE MemberOh bother, well, tale as old as time, but with the Canadian exchange rate as it is, import duties etc., it seems like a bit of an unrealistic investment into a deck of this quality. I’ll see if I can improve the situation any by adjusting the tone arm parallelism, maybe adjusting the optical sensor leading, and the cartridge parallelism, as a sort of “make it work” project. Otherwise I’ll see if anyone else would like to have it.
It really does seem as though even when the stylus is straight before it drops, once it drops, the cartridge pulls to the inside relative to the groove and causes the stylus to bias to the outside.
You must be logged in to view attached files.30 April 2026 at 23:54 #123428James Vinnington
BRONZE MemberGood news and bad.
good news: Adjusting the pickup parallelism really does seem to correct this problem.bad news: screw D is stripped (standard screws should be outlawed) and that’s the screw to make the adjustment properly. For now. I’ve shimmed something under the plastic pin that goes up against set screw D, to rotate the pickup parallelism a small amount. If I can’t eventually get that screw moving, I will tack glue a tiny piece of plastic thereto effect a reversible but longer term repair.
I sincerely hope none of this is offensive to anyone. I’m ultimately trying to keep the deck in service, nobody around here is going to be paying for a replacement cartridge any time soon, and I’m hoping that nothing I do is going to permanently alter the 5005 in a negative way.
You must be logged in to view attached files.1 May 2026 at 19:53 #123436 Mark-sfBRONZE MemberYou should realize with a cartridge likely over 30yrs old and and obvious suspension issue and unknown diamond wear, that you are likely doing damage to your records which may in total be more valuable.
1 May 2026 at 20:11 #123437James Vinnington
BRONZE MemberYou’re right, I got ahead of myself. I won’t use the 5005; perhaps someone will want it for parts or something.
cheers and thanks for the input. -
