Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 Tracking Force Adjustment
- This topic has 5 replies, 3 voices, and was last updated 3 years, 4 months ago by
ghostly.
7 November 2022 at 04:19 #40558
ghostly
BRONZE MemberI have had a beautiful beogram 4002 for years, but recently it started distorting vinyls when the arm gets closer to center, I thought it was time to adjust the tracking force. When I try to screw the arm adjustment, the arm swings left or right and the dial does not really move. Am I doing something wrong ?
7 November 2022 at 16:21 #40559Dillen
ModeratorThe dial wheel can have seized in old lubricants.
It wouldn’t be a first.Martin
7 November 2022 at 16:58 #40560ghostly
BRONZE Memberso what should I do ? can I lubricate it without opening it up as it has the plastic cover or do I have to open it up and lubricate the mechanism like that ? What lubricant would you reccomend?
7 November 2022 at 17:04 #40561ghostly
BRONZE MemberI just rechecked the dial housing and for some reason it was hanging lower so the screw was too low to move, I adjusted to 1.2g and testing now, fingers crossed
7 November 2022 at 21:01 #40562 Mark-sfBRONZE MemberIf you need to lubricate, remove the dustcover and then the tonearm cover can be lifted straight up to gain access the dial and gear. At that point you can check the balance of the arm and the rear counterweight adjustment. You should not need to track at 1.2g. Sometimes the arm cover can get pushed so that it binds the arm. Its height should allow the screw to be centered and the arm to move freely when lowered.
7 November 2022 at 21:41 #40563ghostly
BRONZE Memberwhat would be the target g for a MMC 20E?
