Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 Solenoid Engages When Power Cord Plugged In
- This topic has 4 replies, 2 voices, and was last updated 2 years, 2 months ago by
jfrancis49.
4 February 2024 at 02:21 #52596
jfrancis49
MemberHello All,
I have a BG 4002 type 5513 that is exhibiting the following behavior. As soon as the power cord is plugged into the outlet, the solenoid engages and the arm drops. This is before Start is even pushed on the keypad. Once start is pushed, sensor arm light, 33 rpm light and tracking sensor light up and the arm (in the lowered position) continues across the platter and activates 45 rpm. It then continues to end of play and returns.
Capacitors have all been replaced and many of the resistors and transistors. It has had a complete tear down and cleaning, so it is not a mechanical issue I believe.
Why would the solenoid get power as soon as the table is plugged in? Any thoughts? This was a non-working turntable I bought on Ebay many years ago. I just keep thinking I can coax it back to life.
John
4 February 2024 at 07:15 #52597Dillen
ModeratorShorted solenoid driver transistor?
4 February 2024 at 16:34 #52598jfrancis49
MemberThanks for the suggestion Martin. Just to be clear are you referring to IC2?
John
4 February 2024 at 18:41 #52599Dillen
ModeratorThe component designation depends on the exact type of Beogram 4002.
0TR4 in some versions.
1IC4 in other versions.
Etc.Martin
4 February 2024 at 19:56 #52600jfrancis49
MemberThanks Martin!
