Home › Forums › Product Discussion & Questions › BeoGram › Beogram 3000 (type 5228) belt
- This topic has 2 replies, 2 voices, and was last updated 3 years, 11 months ago by
Clarbasspo.
6 May 2022 at 10:06 #34637
Clarbasspo
BRONZE MemberHi,
the belt of my TT Beogram 3000 (70’S model) is loose. I ordered one on a website that offers new identical copies but it is too short 655mm instead of 690mm for the old one and the round cross section is larger 2.9mm instead of 2.5mm. Of course mine is loose but the difference seems too important to me.
If you owned this TT can you check the dimensions of the belt to confirm the correct ones ?Thanks a lot,
Pierre
6 May 2022 at 10:12 #34638 GuyModeratorI don’t have a BG3000, but from experience with other belts/systems if you order the parts here they will be the correct type: https://www.beoparts-shop.com/product-category/beogram/
6 May 2022 at 15:02 #34639Clarbasspo
BRONZE MemberOk, thanks for the link 😉
Pierre
